where is mobil 1 in wa
  • nelsondude
    nelsondude
    hey, i am wanting to get some mobil 1 vtwin, not into all the debate about what is best etc., i like it and have used it in the past in nz, the only prob in wa its easier to get illegal substances than it is to get legal old mobil 1... weird aye.. can anyone help me out on this.. i am in geraldton but as long as the place will send it to me here i am happy...
    thanx
  • cruzees
    cruzees
    $28 bucks! 1 litre at the auto shop on the NWC highway wonthella.
    cheap plugs tho if ya got an evo or a shovel Nelson
    and gday
  • nelsondude
    nelsondude
    28 bucks... i totally believe that when it comes to oils etc price shouldn't be the deciding factor, but fuck when  a business is ripping you off because of geographics or lack of that product in the area that totally sux...this is the prob i have had trying to source mobil 1, when you do manage to get some its way too expensive.  So anyone know of any buys interstate maybe that will ship.... mmmm, maybe i should start selling it online, do a deal with mobil... become an oil dealer..... thanx for the info cruzees..
  • 2005 FLSTFI
    2005 FLSTFI
    Nelson
    Bought some from Oil Distributors a while back, cost $120 for a box, with each box containing 6x1 qrt bottles. They only sell it by the box as well.
  • shfunky
    shfunky
    Hey Ozroder, what type of M1 do you use?  I use 0w40 in the car but there is also 5w40 , 5w30 ect.
    Gibo
  • nelsondude
    nelsondude
    hi dude,
    just thought i would point out some differences between mobil 1 v twin and mobil 1 for cars... not much but important, instead of a whole lot of crap in my words i have just cut and pasted a whole lot of crap from mobil...
    So how is Mobil 1 for passenger cars different from Mobil 1 for motorcycles?
    First, let's be clear about Mobil 1's overall benefits compared to those of conventional motor oils, whether for passenger cars or motorcycles:
    • Superior long-term engine protection.
    • Superior high-temperature stability.
    • Excellent low-temperature starting.
    • Outstanding engine performance.
    • Low volatility/low oil consumption
    It's a little hard to generalize about the difference between Mobil 1 passenger-car motor oils and Mobil 1 motorcycle oils. That's because not all viscosities of Mobil 1 passenger-car oils have the same levels of zinc and phosphorus, and there are even greater differences among the three Mobil 1 motorcycle oils. In general, Mobil 1 motorcycle oils have:
    • Additive packages balanced differently for motorcycle engine and transmission operation. For passenger vehicles, fuel economy and emission system protection are higher priorities. These require low phosphorus systems and the use of friction modifiers. Motorcycle oils do not require friction modifiers for fuel economy and for better clutch friction less/no friction modifier is optimum. Motorcycle oils allow the use of higher levels of antiwear additives such as ZDDP (phosphorous).
    (Updated December 2007)
    Back to top
    What are the overall advantages of Mobil 1 motorcycle oils?
    In addition to the overall benefits listed above – specifically, high-temperature stability and low volatility/low oil consumption – Mobil 1 synthetic motorcycle oils also offer superior anti-corrosion performance compared to conventional motor oil, which is important in many parts of the country where bikes may sit in garages for several months of the year.
    Compared to conventional oils, Mobil 1 motorcycle oils provide superior wear and high-temperature protection, and promote engine cleanliness and lower oil consumption.
    Once you get past these general advantages, you have to deal with each specific motorcycle oil one at a time to understand the benefits.
    Back to top
    Okay. Let's start with Mobil 1 Racing 4T 10W-40. What does it offer that Mobil 1 for cars does not?
    Mobil 1 Racing 4T 10W-40 is designed for sport bikes. Most of these bikes have multi-cylinder/multi-valve engines and use a common sump, which means the engine oil lubricates the engine, transmission and wet clutch. So unlike Mobil 1 for cars, Mobil 1 Racing 4T 10W-40 motor oil has no friction modifiers, which could lead to clutch slippage.
    The motorcycle oil also has more phosphorus/zinc for enhanced wear protection at high engine speeds and high loads.
    In addition, Mobil 1 Racing 4T 10W-40 has a high performance dispersant/detergent technology for better high-temperature performance and engine cleanliness. Mobil 1 Racing 4T 10W-40 is also offered in a different viscosity grade than Mobil 1 for passenger cars. (Updated December 2007)
    Back to top
    What about Mobil 1 V-Twin 20W-50 motor oil? How is that different from Mobil 1 for passenger cars?
    Mobil 1 V-Twin 20W-50 fully synthetic motor oil is designed for air-cooled, large-displacement bikes. Because of their design, these engines can generate very high localized oil temperatures and high overall bulk-oil temperatures.
    As you know, a typical air-cooled V-twin's rear cylinder gets a lot hotter than the front cylinder – it's a matter of airflow. When it's hot out and you're stuck in traffic, the oil temperature in your bike climbs rapidly. Above about 250°F, conventional motor oil is going to break down. Mobil 1 V-Twin 20W-50 fully synthetic motor oil is good to above 300°F.
    Like Mobil 1 Racing 4T 10W-40, Mobil 1 V-Twin has high levels of phosphorus/zinc and the same high-temperature detergent technology for superior wear protection and engine cleanliness, even at elevated oil temperatures.
    With Mobil 1 V-Twin oil, you can go the full length of the manufacturer's recommended oil change intervals with ease.
    So hope this has helped a bit, and yep i have researched it quite a bit and this isn't all bullshit... there really is a difference... and yep motorbikes are not cars... mmm, go figure fellow astronauts.....
  • CRASHER
    CRASHER
    ..good work fella...
  • hellboundpig
    hellboundpig
     Try inderpendent rural supplies on Flores road Geraldton Mate thats where i get mine
  • hellboundpig
    hellboundpig
     $ 26.70 there mate closer for me than auto one.
  • cruzees
    cruzees
