tyres
  • kensim
    kensim
    i am up for some new hoops,i had metzelars,avons and  of course the dunlops,i was wondering what is considered good k,s from a tyre.and if anyone can recomend a good one. i have found the dunlops a pretty good overall tyre what do you"s think?
  • fastapastor
    fastapastor
    I've just put the new sports tourer bridgy 170/60/17 bt023 on the back of the dyna. Dual compond . Plus is a radial. So far so good. Feels good seems to absord the bumps better.
  • clarkie
    clarkie
    metz 880s for me,
  • BURTO
    BURTO
     Been runnin Metz 880s eva since they came out, 88s b4 that........always liked em! Couldn't fault em!
    After buyin new Fatbob in March, thought the Dunlop D427s were OK.........suprisingly better than expected....................BUT!....................have now gone back to ME880 on the back!
    CHALK & FUCKEN CHEESE!!!    Give me a Metz 880 anyfuckenday!!!!!!
    Besides the obvious in the twisties, after fittin 103 kit, I could light up rear real easy with Dunlop...........not so loose with Metz!!!!!!!
    Burto.
  • lucky
    lucky
    i ride a heratige softail 07,have done 36.000 ks with a metzler 880 on the front [still has a fair bit of tread], put the same on the back after 26.000.on the original 880.
    PS. just in case someone thought of taking the piss ,i don't ride like an old lady.
  • Humbug
    Humbug
    On my second rear dunny and happy with it so far.16000ks out of the first one,but do not have many,infact fuck all corners up here so hard to judge overall.
  • solo
    solo
    Have done 125000ks on my 07 heritage and have just put my 3rd dunlop on the front at 115ks, I have tried mets on the rear but have gone back to dunlop, better mileage and handling
  • V2Evo96
    V2Evo96
    I ran a set of ME 880's (manufactured in Brazil? as I recall) on my 1996 StandardGlide. Fine tyre, no issues, good in the wet and well priced. If you go with the 880's be sure to run an aditional 4-6 psi in the front and 6-8 in the rear in accordance with Metzler specs. Can't tell you about mileage as I sold it before they started wearing.
    I like the Dunlop D407 replacement being the D408, but I don't believe they will be available here until all of the old stock D407's are finished. There were issues of scalloping and vibration with some of the D407's in the states on some 09 models. A lot of info is available about this on the net in other forums.
    i have been runnng michelin commandos not a bad tyre front and rear but have changed to the metzler 880 on the rear recentley and what a diffrent ride smoother more grip , when the front needs a new one i think that will be getting a metz aswell, not sure how many ks out of michelin
  • Magilla
    Magilla
    The votes are in
    I run a 200 rear on the fatty. I do high speed 100 - 130k/hr 80% of the time due to where I live.
    3 Dunlops on the rear......5000km each (actually only got 2500km out of one of them because I ran the pressure too high) . 2 x Dunlops on the front....10,000km each.
    2 x Avon Cobra's on the rear 5000km each.
    Now for the good news....Tried the Pirelli Night Dragon 9750km (nearly double the km's!!!!!) Just fitted my second one this weekend. Guys up here in Darwin are raving about the wear. (excellent) Some are getting up to 15,000km.
    I would have fitted one to the front when I was in Adelaide a few weeks ago but none could be found in the whole of SA.
     Got the last rear in Darwin on Saturday. Bike shop having trouble getting them because of the demand.
    I tried different pressures etc with all my tyres and this is what I have ended up with.
    Until something better comes along, it's Pirelli Night Dragon for me. http://www.pirelli.com/tyre/ww/en/motorcycle/sheet/night_dragon.html
  • Firey
    Firey
    I'm up for tryes - Iv'e been thinking Pirelle Night Dragons - they look like they might stick in the twisties to me, any comments on them before I buy pls - they are on special in December
  • WAGlide
    WAGlide
    I'm running Avon's front & rear. Love them.
  • Firey
    Firey
    They don't make Pirelle Night Dragons rear tyre for my 09 Mod Fatbob - 180/70 16 so I am thinking the Metz 880
  • Firey
    Firey
    Farrrrking oath - overtaking me on the inside Ha - $250 looks good - Im in - cheers
