Online: imoo6170
starter motor?
  • cruzees
    cruzees
    Gday,
    got a clicking sound happening when i press start button.
    battery fully charged just no turnover only clicks around the starter motor area maybe above at another relay looking box.
    was starting intermittantly if one played around a bit but now just all clicks.
    tapping the starter not working as it sometimes does on cars.
    any tests or places to look before i start unbolting bits?
    thanks in advance
  • Hound_Dog
    Hound_Dog
    Have you tested the battery old mate? If so, what were the volts?
  • cruzees
    cruzees
    battery working fine, cranks other bike fine and tried another battery that i knew was sweet out of otherbike.
    still clickin :)
  • als1200
    als1200
    gday Cruzees,
    just a thought, get a wire and go from the main battery feed to the starter and bridge it to the ignition feed on the starter.  Just be carefull not to touch any metal parts at it live from the battery......sparks!
  • cruzees
    cruzees
    Ok ...
    just shorted starter with a screwdriver as ya do with a car .... it whirrrs but no engagement to start ( no turnover)
    so starter getting power.
    but when hit starter button still clicks from around rear of bike ..sounds like its not from actual starter tho . bit higher...
    lol Bucket . if it was a honda i,d just leave it out front for some prick to steal it rather than fix it.
    thanks for help so far ..
    just trying tests so i dont buy something i dont need
  • als1200
    als1200
    i dont know what starter your running but mine a fantastic NIPPON DENSO (made in Japan) starter.   if i could only get a bigger battery into the tight area i would be better off.
    sounds like the solnoid plunger in your starter  what year bike is it ?   you could try and bypass the starter button and run a wire from battery 12v to the exciter wire terminal on the starter (spade terminal) if it still clicks it is not the switch or wiring or relay ,just touch the the terminal as it may or will turn the mtr over and make sure its not in gear  no need to have ignition on .
  • rider
    rider
    Sounds very much like the starter solenoid isn't making contact..
    Depending upon which type it is, you may be able to pull it to bits and clean the contacts,,, if there's anything left of them.
    If not, and it's use-by date has arrived,,,, you know the story.
  • als1200
    als1200
    im not sure what bike you have nor what starter but you may have the starter solinoid tucked up in the frame (near the battery?) could be causing some of the problems.
    can you follow the main battery cable to where it ends?
    yep if its a evo same as a hilux 3y with a diffrent nose cone , a week trying to sort mine out and i had one in my drive way the hole time
  • cruzees
    cruzees
    87/88 evo softail.
    gettin a bit hazy now , will give it another go in the morning.
    cheers for all help , this forums a bewty for knowledge and the sharing of it .
    thanks
  • als1200
    als1200
    if its the later nippon starter, they use gear reduction through the clutch in the front housing. the contacts are just under the 3 screw cap at the back with the plunger. they have a coil which pulls the plunger down which in turn gives you the 12v battery supply to crank the motor. main things that play up on them is the contacts (best thing to fu*k them up is winding the motor over with low battery voltage) and the plunger (the contacts touch this in the working mode). Japs build good simple gear reduction starter motors.
    you may have a early style evo starter which is simler to a shovel  which has a seprate solnoid to main starter.
    + 1 to what als1200 said
  • Burnzi
    Burnzi
    I had this happen and it turned out to be the 2 screws that hold the cap onto the solenoid, workin loose, fixed a shovel on the Lap of the bay ride with exact same problem. His screws had come out far enough to be arcing fireworks everywhere under the pos(?) wire
  • cruzees
    cruzees
    ok........
    ran a wire from battery to starter..... turned over fine.
    still clicking when i use the normal button to try and start....
    + one to what kiwidav said  get  a 4 pin 12v 30amp  relay  from repco or any auto shop   85 earth   86  12v from old eciter wire  30 from 12v batt or ing   87 to the starter   or work out your  old relay wires and replace that way. buy a bosch  thay are the better relays i have found  over the years.
  • cruzees
    cruzees
    thanks for all ya help fellas.
    relay ....tucked up behind battery box .... prick of a spot for big hands  but  sorted and back annoying the neihbours
    onya guys
  • Burnzi
    Burnzi
     Gotta love the wealth of info on this forum
