FXR forward controls
  • Nibbla
    Nibbla
    Can anyone tell me if Dyna forward controls bolt onto an FXR frame, they both have two mount holes on the frame so I'm thinkin they will work but may need the rods to master cylinder & gearbox shift lever adjusted or fabricated.
    Cheers Nibbla
  • Nibbla
    Nibbla
    Thanks angustriple, thats the info I was after.
