Anyone got a mukuni carby on their twincam 88? wanting more bottom end power
  • 99Dyna
    99Dyna
    Hi, i am looking for a bit of extra power, i was looking at the mikuni 42 to replace my stock carby on my 99 model dyna twincam 88 cube, Looking at mikuni website - http://www.mikuni.com/fs-products_guides.html they say there is approx 25% or approx 10 to 20hp difference, does anyone know how true this could be?, whats everyones thoughts on this? will it be worth the money? or should i just go new headwork, cams, pistons? any other suggestions for increase of bottom end power?
    thanks
  • Ozbernie
    Ozbernie
    You will notice a crisper throttle response, but not torque by just changing to the Mikuni HSR42 carb. For that you will need to add some more cubes.
  • 99Dyna
    99Dyna
    at present on my stock carby, i have the thunderslide kit in it, which gave it a heap better response than the stock one. just checking out the woods website, their dyno reports look impressive. i am still up in the air about modifying the internals of the motor, but looks like i will have to lean that way.
  • 99Dyna
    99Dyna
  • 99Dyna
    99Dyna
  • Dynamic
    Dynamic
    If you want a little more snap off the line, I'd just lower the gearing. Use a smaller pulley on the gearbox, or convert to chain. I like chains, Luddite that I am. Make sure that one of the sprockets has a prime number of teeth. Like 23 or 47 or 53.
  • Noodle
    Noodle
    LUDDITE ??????
    1. One who fears technology (or new technology, as they seem pleased with how things currently are...why can't everything just be the same?)
    2. A group led by Mr. Luddite durring the industrial revolution who beleived machines would cause workers wages to be decreased and ended up burning a number of factories in protest
    A luddite generally claims things were "just fine" back in the day, and refuses to replace/update failing equipment/software/computers on the basis that they were just fine 10 years ago.
  • Dynamic
    Dynamic
    Chain drive is more like back to the future. With the high quality sealed lube chains available now, they are way better than ever before, while allowing a less expensive final drive with less mass and more flexible gearing options. Replacing a worn chain is duck soup, compared to an endless belt. It also allows a wider rear wheel, if that is in your plans.
