Online: John.R, Hilly
V&H Fuelpac
  • tuc
    tuc
    if anyones running a fuelpac could you give me some feed back on the proformance of them
    thanks
  • kingchops
    kingchops
    I've owned a couple, they are good as a cheap no brainer solution for stage 1, but not much good for anything else.
    Performance was good on the 07 Sporty I had and ok too on the Dyna but on the Dyna, I found I had a crap load of popping on decel with the fuelpak.  Most of that went away with the TTS.
  • tuc
    tuc
    thanks
    will be going with TTS more suited for down the track when i decide to do mods in the future
    tuc
  • SoftailSteve
    SoftailSteve
     fuelpac very easy to install
