Online:
Stuart
Cheap lowering job !!
ductor
Bowsaw to get the old things out you need a press to take the pressure of the bolt end of the shocks then you remove a circlip, the plate with the bolt then comes off and you remove the internal locking nut , then spin the new long stud things in. (Softail)
