Hi Guys
Looking at getting exhaust pipes for my 2010 V-rod Muscle
Was going to get the TAB pipes with the fuel manager and filter
However a lot of people say that the TAB fuel manager is not that good
The harley dealer reccommends the screaming eagle tuner
My understanding is that this is basicly just soft ware
Can some explain why its so expensive (they quoted $703)
Are you able to use this software on a number of different bikes,,, if this is the case then what is stopping one from just finding some one else with the soft ware and using theirs
Old fart that has never owned a bike with EFI,,, the old shovel and BSA's with carbies i understand can knock tha baffles out re jet and re tune
I like the look of the TAB pipes just need to make a decission on what tuner/fuel manager to get
Can I just knock the baffles out ( or open them up a bit ) of the standard pipes fit a tuner and get it to work it that way
Any thoughts and or advise would be most appreciated
Slick
S/E tuner and some quality dyno time ............ you can't go wrong. Bang for your buck and unlimited tuning ability.
