Online:
imoo6170
Knocking in primary case !
Lastrain
If you don't find anything with the compensator have a look at the adjuster, the later models with the auto adjuster sometimes don't adjust properly and will knock when cold, mine did it and still does occasionally, had the dealer stuffed for a while they pulled the primary cover to check the compensator and found all was good, there was another thread on here somewhere about it.
There are a couple of things you can do to sort it out
1. give it a bit of a hand to adjust up by pushing on it hoping it moves up a notch on the adjuster.
2. while riding give it hand full of throttle loading up the p/chain then back off the throttle really quick to create slack in the p/chain allowing the adjuster to move out.
Would defiantly be checking the compensator nut before trying option 2
