Online: Wanderer57
Engine rattles when cold
  • gonzo
    gonzo
    Hi all.
    I've just put my 07FLHRC in for service at Frasers. It's developed an engine rattle when starting from cold. Disappears after a minute or so. It's quite loud, like piston slap in a two-stroke, but it goes away and the bike sounds and performs fine. I'm wondering if it's an oil-related problem.
    Details: 13,000km, stock everything incl exhausts, mineral oil, treated pretty gently.
    Any thoughts?
  • gonzo
    gonzo
    Sorry RT, "bleeding down". Please explain....
  • gonzo
    gonzo
    Thanks RT.
    When I dropped it off at Frasers I said, "is this likely to be a hydraulic lifter problem?".
    "No, not likely" was the reply. I'll see what they come up with....
  • gonzo
    gonzo
    It was hard to tell, but I think it was on the front cylinder in the rocker box area. Didn't sound like the cam area, and it was louder on the RHS, so I don't think it was the primary. I'm a bit vague because I only get a short time, <1 min, to trace it before the noise disappears. I think you're on the money though.
  • gonzo
    gonzo
    OK,
    Frasers said they couldn't find anything wrong, and it is probably a primary chain. I don't believe them...
    Anyway, they said I can't hurt it by continuing to ride, which, if it is a lifter seal leaking, is probably correct advice. We'll see....
  • gonzo
    gonzo
    Point taken, RT. Good advice. Congrats on your kilo-postings, btw.
