Oil Light
  • Sparra
    Sparra
    Hey fella's...Just took the bike for a ride after getting the cam all sorted(1995 FXSTC) and noticed after it gets hot the oil light starts to flicker at idle...It does seem to idle a fraction slower now so is it just a matter of adjusting the idle or is there something more sinister going on???
    Cheers...Sparra
  • Sparra
    Sparra
    Thanks fellas...I would say it's below 1000rpm so I will check connections and adjust idle...No other noises and is running great....Thanks for the help...
    Cheers...Sparra
