Online: Stuart
comp nut
  • goobs
    goobs
    Goobs here again
    What are the best methods of keeping engine locked whilst doing up comp nut?
  • goobs
    goobs
    Dave
    Sounds good will do
  • BURTO
    BURTO
     Yeah, obviously you need to use nice clean rope, but the worst thing your gonna leave in there is maybe some nylon fibres, which will burn away real quick.
    ..........and if you find that the rope wont pull out, chances are you weren't on the compression stroke and have got the rope jammed in a closing valve.
    Just turn engine back the other way till it releases.
  • goobs
    goobs
    Burto
    Rope sounds good shall give it a go.
    Is burto your real name or is that an anagram for TURBO??
    Have I just exposed a secret identity??
    Just havin a laugh
    Thanks for advice,have s good one.
  • goobs
    goobs
    G day Burto
    used the rope, works a treat, would recomend it to be the better way.
