b0mb3r needs a tool
  • b0mb3r
    b0mb3r
    hi guys
    ok now dont flame me to much but all my tools are metric for my old bikes and guess what ..... the friggin things dont fit, so what socket sizes and alan key sizes do i need .... and the bloody hex thingy do i need a poxy usa hexy thing to
    thanks guys
    yank bike  yank sizing af but some will be metric alot of aftermarket stuff comes with metric sizing and torx bolts  oem
  • BURTO
    BURTO
     Might be cheapa to just trade the tractor back in on a jappa!!!!
    I have a metric spanna............it's more common name is a "shifter"!! ("cresent" for you Sandgropers!)
    yep he could do that ,have no leaks,no rattals,no squeaks and no style and be like all the other want ta bees maybe buy a varago
  • Stewy
    Stewy
    Hey b0mb3r, ride to a BIG toolshop. If they are switched on they should be able to advise you on tools and torx sizes for your hog.
    your bike is out the front take the tools out and make sure.
    You might get away with a small AF kit and a torx kit.
    Be aware some torx kits dont have all the sizes you need. This kit will fit everything genuine, torx and hex (allen key) on my streetbob
    T&E Tools Part No TX037. Good quality and about 50 bucks
    Stewy
  • evoshovel
    evoshovel
    I check out the assorted tools in bins in places like cash converters and find they sometimes have the bigger sockets like 1 1/2 and 1 1/8 and so on. These are the kind of sizes you need for clutches and front sprockets. It dosnt take long to build up a kit and Id rather get  better quality second tools than brand new poor quality stuff.
  • b0mb3r
    b0mb3r
    thanks for all the replys guys will look into it ..... will have a look at T&E tools as well Stewy
  • b0mb3r
    b0mb3r
    "Might be cheapa to just trade the tractor back in on a jappa!!!! "
    wash your mouth out with soap
  • b0mb3r
    b0mb3r
    Seems that im going to need the tools sooner rather than later. Went on  a HOG poker run today and the bike went home on the back of a truck ..... only one person stopped to see if i was ok ....... hmmmmmmm
    hi maybe you just forgot to put petrol in it , harley's don't brakedown  ?  enjoy your new bike
