Over Heating on HD
  • Taffymarsden
    Taffymarsden
     Wouldn't worry about it. Getting your message loud and clear.
  • PigironBob
    PigironBob
    just my 00.02 worth on this.
    You say you swapped out the original ECM for the TM, I would be getting a TTS and then putting the original ECM back in. Get a laptop computer running XP or Vista for the software and then do the tuning your self. Lots of help available in http://www.hdforums.com.au/Default.aspx?tabid=71&view=topics&forumid=27 .
    Will well be worth the money and especially with your planned mods. Put the Tm on ebay or use it as a paper weight.
