Tire and Suspension Pressures for 98 Road King Classic
  • daccadan
    daccadan
    Hi all-I have just bought a 98 Road King Classic-does anyone know the reccommended tire pressures I should be running-Google says F38psi R44psi-seems a bit high?
    As well does anyone knoe the factory air suspension pressure settings?
    Dan
  • Aunty X
    Aunty X
    In addition to the above, I would strongly suggest not to muck around with the front shock pressure until you consult your HD service centre for advice on that one.
