Online: Soapbox2627, Hilly
Tire and Shock Pressures 98 Classic
  • daccadan
    daccadan
    Hi all-just bought a 98 Road King Classic-beautiful bike. This has probaly been answered a dozen times but what is the recommended tire pressure for this bike(I didnt get a manual). I googled this and it said F38psi R44psi-seems a bit high?
    As well does any one know the factory settings for the air suspension?
    Dan
  • CHARLIE
    CHARLIE
    Don't beleive what you read on the frame 25psi in the front and if you are 2 up30 to 35 in the rear and yes it will take the pressure my 96 road king did for years and worked well,handled like a dream;would not handle with the pressure harley said to to put in.
  • CHARLIE
    CHARLIE
    Sorry i sent you shock pressure,tyre 36 front 40 rear i find it ok.
  • daccadan
    daccadan
    Cheers Thanks for the info
  • kaboom
    kaboom
    id agree with charlie  my 07 r k has 36  front 38 rear  &20 to 25 rear air shocks
