ATF in primary?????
  • Wingy
    Wingy
    Have been using ATF type F in my primary (as suggested in this forum) and noticed a fair bit of crap on the magnet of the sump plug....about the same at the last 2 oil changes.........change my oil and filter every 5000 klms.....22000 klms all up.........Its got me worried as the engine oil sump plug is spotless every time .......using mobil 1 in the engine.
     Hi Wingy,
    well you always get crap out of the clutch & magnet picks it up. i would normaly change primary more than the engine oil.
    i've used ATF Type F from new 01 over 80,000k and a lot of it racing no problem. still original primary chain.
  • Wingy
    Wingy
    Krash ...thanks for the reply ....was just a bit concerned there is a fair bit of talk about  compensator wear.....cheers.
  • berms
    berms
    I have some Redline High temp ATF ready to go in my primaty..... do I need a new clutch cover gasket every time I change the primary oil?
    Have the new bikes ( mine is 01 year ) still got an inspection cover? i just take inspection cover off to do primary chain oil change.
  • Burraburra
    Burraburra
    Derby only on my 09 Softail.
    must only use the inpection with mid control shift as shift has to come through primary.
    with forward controls i can see how it would clean up the looks, just it's easy doing primary oil change through inspection & checking primary chain adjustment.
