Larger Peanut Tank
  • Kel.48
    Kel.48
     Hi I'm new  to the Harley family and I have just got a new 48 sportster, what I'm looking for is a larger peanut style tank, something that is longer,wider and still has that peanut shape. Now I know I cant buy one strait of the shelf, but does anyone out their know of a place that I could get one made up thats in Australia. The size that I would like it to be is about 16 litres
    Kel
  • Deadwood
    Deadwood
    Probably best to buy another tank so you can keep the original and take it to a panel beater and get them to alter it for you.
    There might be other options in the way of steel fabricators but the guy I bought my bike from was a panel beater and he did it to the tank on my bike and to the tank on his new Fat Robert.
  • Kel.48
    Kel.48
     I will be riding to Cloncurry  120ks and Camooweal 220ks away. I like the idea of getting one of ebay  and taking it to a panel beater
    Kel
  • Cubicinches
    Cubicinches
    Take two tanks
    1/ Split one tank length ways through the middle
    2/ Cut the centre length ways out of the second tank. You can squeez about 3 inches
    3/ weld the centre piece into the two halves of the first tank.
    The biggest after Market Peanut Tank is a King Sportster . It holds 13 L , but is only avalaible to fit up to 2003.
    Your Bike is EFI and has a Fuel Pump in the Bottom of the Tank, So to fit one of these you would have to get the Bottom of your Tank Grafted in to it, 1 for the Pump and 2 for the mounts. It's the only way..
  • Kel.48
    Kel.48
     Thanks Dave I'll look in to it ( shit I sound like a poli )
  • Rocky2010
    Rocky2010
    Partner has a 883 Sportster Low she gets around 240ks out of her 12.5ltr tank, more than enough.
    After 200ks you want to stop and have a rest anyway.
  • ductor
    ductor
    Have a look at www.justgastanks.com
