Online: wildchild, Retroman
Stop & Go Tire Repair Kit - www.tomcatdistribution.com.au
  • Tomcat
    Tomcat
    Hi Guys,
    We have Stop & Go Pocket Tire Plugger Repair Kit that is suitable for all tubeless tires (even cars and larger vehicles - ideal for vehicles with a space saver as the spare).  It is designed as a temporary punture repair on the side of the road to get you out of trouble and should be professionally repaired by qualified persons at the earliest opportunity.
                                                           Stop and Go Pocket Tire Plugger
    Will sell via our website directly to end users and we are set up for distribution to retaiers/dealers.
    Stop & Go Pocket Tire Repair Kit and Mini-Air Compressor now available with a few more items from their range to come.
    Details, video demo and instructions available at www.tomcatdistribution.com.au.
    For dealers fill out the application and once yu have set up your account wholesale pricing will be shown when logged in.
    Thanks
    Damien
    Tomcat Distribution
  • Tomcat
    Tomcat
    iMC Motorcom Headsets Now in Stock
    Quality Motorcycle Headsets – 2 year Warranty
    6mm thin speakers (8mm in soft pouch)
    Full face (soft cord) or open/flip face (boom) microphone options
    iPhone/mobile phone headsets
    UHF/CB radio headsets
    Specific headsets to suit BWM, Harley, Honda & can-am Spyder OEM connections
    Waterproof Firewire connector
    MP3/iPod speaker sets
    2 year warranty*
    Also coming soon we have a range of quality luggage and accessories from the US in
    Helen2Wheels and Marsee that have some innovative packing solutions for the everyday and touring rider.
    Want to buy these products at your local store or dealer?
    Simple - let them know that you want these products and get them to contact us
  • Tomcat
    Tomcat
    Tomcat Distribution - iMC Motorcom
  • Tomcat
    Tomcat
    Tomcat Distribution
    Marsee and Helen 2 Wheels have arrived in stock and now shipping
    Marsee
    Marsee
    Marsee Products offers a wide range of tank bags, rear bags and accessories for every bike! Innovative design and advanced technology makes Marsee Products the perfect choice for riders.  Some of the items are listed below.
    Helen 2 Wheels
    Helen Twowheels Bags and Straps The Helen Twowheels Super Packing SystemTM helps you pack everything you need for a weekend trip or cross-country trip onto your bike. With three main types of bags- the Roll Top Sack, Cord Close Sack and Clothes Sack- plus packing straps, you will have everything you need for your trip! All of the bags are made of black, high-quality, rugged, waterproof material that is laminated on the inside with a layer of polyvinyl. On the clothes sacks and roll top sacks, all seams are sealed and, once rolled, both styles of bag are waterproof. All have the unique reflective, slotted strap the entire length for attachment versatility and only the finest quality nylon hardware. Made in America.
    Helen 2 Wheels Super Pack Straps
    Helen2Wheels Super Pack Straps
    The Super Pack Straps come in a four piece set (two 6" pieces and two 5' pieces). These attach under the passenger seat or the top box (you just need 4 mounting points for each part of the strap system) and keep your saddle bags available during your trip. They will hold bags on the rear seat OR above the saddle bags for 2-up touring. They work well with the H2W bags, but will work with any bags that you have.
    Benefits of H2W Super Pack Straps:
    - Available in several colours
    - No elastic to wear, fray or stretch over time or break while riding
    - Made from a thick, heavy strap material
    - Plastic hardware to protect you and your bike
    - Strapping material will not stretch while riding, so your load remains in place
    - Secure d-rings will not loosen or break
    - Four strap system allows mounting versatility
    - Short straps with d-rings can easily stay on bike when full strap system is not in use
    - Replacement strap pieces available should you lose one
    Marsee Compression Bag
    This bag is simply amazing and will reduce the contents to about 40% of its uncompressed size! The bag will compress from 40cm (16") tall to a very compact 13cm (5").
    Helen2Wheels Roll Top Bags & Sacks
    Helen 2 Wheels Clothes Sacks
    The Helen Twowheels Clothes Sacks were developed for those people who want the convenience of easy access. They are built to seal like the H2W Roll Top Sack but open the length of the long side so you can get to all those little things in there. The H2W Clothes Sacks are made of black, rugged, waterproof material that is laminated on the inside with a layer of polyvinyl. The seams are sealed and once the top of this bag is rolled down three times, it is waterproof. As with all H2W bags, there is a slotted strip of reflective material along the length of the bag to run your straps through so the bag does not shift side to side while travelling. These are not compression bags and, although you can fit a lot of stuff in them, they will never pack as tight as the regular Roll Top Sack.
    To pack, stuff items into the two ends first (tip: purchase mesh insert tips to push into the ends of the bags for easy packing). Then load the middle of the bag. Once packed, close the lips of the bag and roll down three tips. Clip the ends of the bag, then clip the two straps that compress the middle of the bags.
    Marsee Dry Bags
    Marsee Dry Bags
    These durable waterproof dry bags keep the elements out of your gear. They are a great way to organize, whether you're packing for hard or soft luggage. Small enough to throw in as an extra bag on trips.
    These bags are the perfect packing bags for inside your tank bags or existing hard luggage. They are easy to grab when you get to your destination.
    iMC iPhone Motorcycle Headset
    iMC Motorcom iPhone Headset
    The iMC Motorcom HS 500 range is the perfect product for motorcycle riders with the latest generation of smart phones. Now two-wheeled riders with 3.5mm (standard headset jack) equipped phones such as the Apple iPhone, Palm Pre, and Blackberry Storm can take full advantage of the features their phones have to offer. The iMC speakers and microphone give you big sound and clear voice in a small, clean package. A handlebar push to talk button seamlessly handles voice and/or music control for the iPhone 3GS, Palm Pre and other smart phones.  Available with either a boom or soft cord microphones.
    iMC Motorcom
    UHF Radio Headsets
    iMC Motorcom have a range of headsets for UHF radios for communication in a group. Also perfect to trainers. An option of boom mic for open and flip face helmets or saft cord mic for full face helmets.  Included is a Push to Talk Button (PTT) and a number of adaptors to suit 3.5mm and dual 2.5/3.5mm plug connectors.  All iMC Motorcom headsets have a 2 year warranty.
    Stop & Go Pocket Tire Plugger Kit
    This revolutionary new device easily installs mushroom shaped rubber plugs into all tubeless tires while staying on the wheel. The Plugging device 'drives' the plug into the hole with a turning of the hex wrench. The plug expands under pressure to fill the punctured area. A firm pull on the stem with your pliers seats the mushroom head on the inner wall allowing no air to escape. This technology insures maximum reliability while reducing your downtime in any situation.  Includes 15 plugs and spare plugs are available in bags of 25.
    forward to a friend
    Want to buy these items locally just ask you local store to get in contact with us as we are always looking for dealers
  • Tomcat
    Tomcat
    Tomcat Mini-Air Compressor
    Price now down to $31.95
    Same pump we had previously now made and supplied directly to us.
    If you would like to stock these get in touch with us for details.
    If you would like to purchase one click here or on the image
    Ideal for Motor Cycles, ATV's and Scooters - Not designed to inflate car or truck tyres
    The Tomcat – Portable Mini-Air Compressor measures only 10.2cm x 5.1cm x 15.2cm making it possible to be carried on virtually any motorcycle, scooter or ATV. The built in gauge allows you to observe the increased pressure with a reading up to 120 psi. It also comes with a built in LED light letting you know that it is receiving power and helps you connect to the tire valve after dark. Your motorcycle tire will be fully inflated in less than 10 minutes. And with this unit you also have the ability to inflate sport balls & camping equipment. On the road or in the wilderness you will always have clean outside air available and there’s never a need for replacement parts or re-fills.
    Contents
    Compressor unit 12V
    Built in LED light
    Built in gauge 0-120 psi.
    10cm tire valve hose
    167cm power cord fits your battery tender wire
    30cm extension alligator clips
    91cm extension lighter adapter
    Sports needle adapter
    Inflatable adapter
    Complete instructions
    Rugged zippered carry case
    Measures 10.2cm x 5.1cm x 15.2cm
    Weight: 415 grams.
  • Tomcat
    Tomcat
    Maxxeon Pocket Floodlight
    as reviewed by webBikeWorld
    Now in Stock and distribution to dealers and resellers
    $37.95rrp
    Pocket Floodlight
  • 308bever
    308bever
    how much for the helmet mounted head set tomcat?
  • Tomcat
    Tomcat
    Hi Bever,
    It depends on what you want the headset to do and interconnect with.  There are different prices for different configurations.
    Let me know your needs and purpose and will see what suits.
    As for Open Face and Full Face helmets there is no difference in price.  Only difference is for a half helmet.
    Thanks
    Damien.
  • 308bever
    308bever
    i was really after headphones for music only, to suit an openfaced helmet, thanks (((-:
  • Tomcat
    Tomcat
    Hi Bever,
    You would be looking at the HS-200 for speakers only.  RRP $49.50.  This set is for both open/full/flip face helmets.
    Thanks
    Damien.
  • Tomcat
    Tomcat
    Now Available
    Replay XD
    Small & Simple
    That’s what the Replay XD1080 is all about. Starting with the small design of the Replay XD and a clean sheet of paper, we managed to put full HD into a small package.
    Featuring a water-resistant, hard anodized, rugged aluminum housing for your extreme adventures. The Replay XD1080 is the smallest and lightest full HD action-camera on the market.
    Simple, two-button ON/OFF and Start/Stop make the Replay XD1080 camera easy to operate. Simply turn it ON and Press Record to Start. The built-in LED & Vibration Feedback tell you that you’re ready to go.
    It’s really that simple.
    Rotate, Tilt, Swivel, Clip, Mount, Etc.
    Replay XD1080 can be mounted practically anywhere due to its small form-factor and all-round shape. There are two mounts included with each system to get you recording in no-time.
    HeimLock Mount (Swivel/Tilt): Features spherical adjustment with an eccentric cam-lock for a rock solid mount. Over 1,036,800 Mounting Positions with 360º lens rotation, 360º camera rotation, and 8º of tilt, not including the unlimited areas you can mount 1 of 4 included SnapTray VHB bases.
    Included are 2 Flat SnapTrays and 2 Curved SnapTrays with 3M® VHB adhesive to securely mount to smooth surfaces: metal, paint, powdercoat, LSE & HSE plastic. 3M® VHB adhesive ensures secure mounting and removal without harming your surface.
    LowBoy Mount (Fixed): Lowest profile mount, offers 360º lens rotation. Designed to be low and out-of-the-way. Compatible with our SnapTray VHB bases.
    HardCore (Billet): Optional billet-aluminum pro mounts are available for the most demanding action and motorsport applications. Tubular, Flat, Curved, Tripod, Universal, & Specialty mounts are available.
    You get the above in the kit
    RRP is $339
    visit www.tomcatdistribution.com.au for more information.
  • Tomcat
    Tomcat
    Some new luggage products to suit all types of riders and bike as well as some rain gear and bike covers.
    MotoCentric
    Click on any of the images to browse further.
    High quality with Lifetime Warranty on Luggage and great pricing
    Stock arriving soon so have a visit and let us know what you like or request a back in stock notification.
    Don't forget our Stop and Go Pocket Tire Plugger Kit also.
    Thanks
    Damien
