Online: Retroman
Supertrapp Pipes for 09 Fatbob
  • Firey
    Firey
     My Mechanic Mate reckons these are the go to put on my 09 Fatbob - I just have the standard headers and mufflers,  apparently with these Supertrapp pipes you can take plates out for low range power - or add them for top end - in 5 Minutes, does anybody have them on - or any info - do they scrap in the twisties?
    Item N 128 -71574 - $659 usd
  • BURTO
    BURTO
     Try the piccie again Firey......or tell us what type they are - 2-1 , 2-2?. The number dont come up on Supertrapp website search!
  • BURTO
    BURTO
     OK Firey, I found em! 2-1s, theyre gonna be good for performance, easily tuneable but unfortunately theyre gonna scrape. I can tell by how low they go to get under the mid mount pegs. Had the same problem with the Bubs, I think I showed you. This is probably gonna be an issue with any pipes for the Fatbob cause they come with the option of midmounts!
    As you know I had to cut out about an inch to raise em up, easy on black pipes, not so on chrome/stainless.
    The Bubs scraped earlier than the stock pipes, these look like they'll do the same mate.
    Burto.
  • Firey
    Firey
    Yer - thought so - I had the pic up - don't know what happened there - thanks Mate - I like 2 -1 going to do something one day - more herbs and better suspension - and TTS also.
