Online: HD17, Stuart
broken compensater nut
  • goobs
    goobs
    Gday from down under,
    I snapped off my compensater nut because I turned it the wrong way. Half of ot is left inside my compensater sprocket extension shaft with some thread still left on my crank shaft, how the f@&% am I gonna get this off with out grinding off my extension shaft?
  • PigironBob
    PigironBob
    got a picture?
  • goobs
    goobs
    Gday Bob
    No picture, but if you can imagine your crankshaft and your compensater extension sprocket shaft, inside that shaft is your crank with about an inch of thread on the end, that last bit of thread has the rest of my comp nut on it. Its in about 1 1/2 inch, too deep to reach with grips.So I can only imagine having to have to grind off the end of my sprocket shaft to the end of my crank to get any type of tool onto it. I,m nearly in tears just thinking about it.My compensater is off so is my sprocket, any
    suggestions??
    Chris
  • goobs
    goobs
    Who,s Scotty?
  • DaveP
    DaveP
    Its a bit hard to gauge how much work will be required without pix. If people can get a look I am sure a few will be able to respond with some solutions. We once had one on an old Genny shovel that had to be cut off with a blow torch, others have been a little fiddly but with some heat, knockometer and persistance they came of with no damage.
  • PigironBob
    PigironBob
    What bike and year is this on? Reads like it's the nut that holds the clutch on.
  • PigironBob
    PigironBob
    No idea how you are going to deal with that.
  • TheBoss
    TheBoss
    Get yourself an easy-out kit or another method that might work is left-hand drill bits. Add penetrating oil that will work it's way down the threads. Applying a torch to heat it up might help but don't over-do-it either.
  • goobs
    goobs
    Gday Dave,
    Yes the compensater assy is completely off, however the comp nut has sheered off right at the crankshaft which in my case is inside my sprocket shaft about inch and 1/2.Dilema is I Have to remove sprocket shaft to get to last section of thread from comp nut to get any type of tool on it.Still crying. Also it is a really good way to learn which way a comp nut comes off!!
  • goobs
    goobs
    Beeza
    Cant drill into nut as nut is inside comp sprocket shaft?
    By the way your good at those photos
  • goobs
    goobs
    Dave
    Not much good with computers let alone taking photos and then putting them on computers, bike is 1987 FXRP apparently an import from US,ex police bike and labelled high speed,Frasers here in Perth say the comp shaft differs from standard FXR and availability may be a problem.
  • goobs
    goobs
    Gday people
    After pulling my 1987 FXR to bits and hopefully fixing all my problems I,m left with my negative battery cable. One end obviously goes to battery and the other end goes where???. I think Ive had one too many Wild Turkeys. Please help this drunken old fool!
    transmission case or starter mount bolt make sure its clean where you mount it no paint
  • goobs
    goobs
    Perthhog,
    Thanks for advise started straight away. I,m sober now!
    Goobs
  • goobs
    goobs
    Perthhog
    Do you think on an EVO that its important to have one of those breather filter devises on crank case breather pipe or just a standard hose as per factory
    Goobs
    yer mate i would use a crank case breather filter  it does help reduce oil leaks  and oil fumes entering the intake which can produce engine pinging  if your mtr breaths a bit  if you look in my avator photo just below the rear of the frount ex pipe you can see my chrome  breather made by custom chrome  it is a bit low there  i have to replace about once a year  due to being grinded away. but is the best spot cause i get bugger all oil mist on any chrome .
  • goobs
    goobs
    Gday
    Ive not blocked if off just have hose attached to crank case pipe. people say your crank case can suck air as well as blow?? Can it??
  • goobs
    goobs
    Another question, Ive heard people talk about a product that they put on their final drive belt to stop noise like a screaching. Is their such a product or is it just lubricant of some sort??
    what ever u do dont block off  other wise you will have lots of oil leaks the way u have done it is the right way  from crankcase to crankcase fiter and bypass going back in to the intake , as for the belt  lube i have used silican spray and a bit crc  but only last a few hundred ks i have a tube of harley  poly lube coming  this week which is made for sportstars with the primary belt  ,i got the info from another us forum so i will give that a shot in the next few weeks . make sure your belt is lined up and not to tight or loose as thay can make alot of noise
  • goobs
    goobs
    Perthhog
    Whats average running temp of oil for an evo ?
    Goobs
