Dry Riders Stuck to Exhaust Pipes
  • Snowie
    Snowie
    Has anyone had this problem?  The Dry Riders are the quilted kind, with the sort of plastic type material on the outside.  How can we get the bits that are stuck to the pipes off without damaging the chrome?
    Dunno if this is the right place to ask this, but I wasn't sure where else to put it!
  • lcpltac
    lcpltac
    Oven cleaner, let it soak then gentle polish and wash off.
    Had to use it a couple of times now, just be careful when washing if off, it is caustic. You don't want to wash it toward anything fragile.
  • Snowie
    Snowie
    Oops ... shoulda put this in the General Workshop forum
    Thanks LCP we'll give that a try!
  • multinut
    multinut
    if you go for a ride and heat the exhaust pipes up - just wipe of all the excess dry riders off - then when cool again just use some chrome polish and elbow grease - it worked for me
  • Snowie
    Snowie
    Thanks lads :)
