Online: GGUser731
pipes
  • Harvey
    Harvey
    Big shot staggered, the big radius are everywhere. My self am lusting after Martin bros. shockwave but keep that quiet don't want
    them spreading like those big radius.
  • Dan
    Dan
    Yes the BR's are common, but thats prolly coz they look so good, but If I were to go again I'd do these------> http://www.paulyaffeoriginals.com/pyo-products-phantompipes.htm
  • berms
    berms
    Which girlfriend should I have.... the blonde or the redhead???
    Pipes are personal.... get the ones you like the best, as you will be the one who has to look at them everyday.  Just saying.
    Just for the record if I had to choose between those two pipes only my vote goes to the big shot staggered.
  • FatboyGooch
    FatboyGooch
    Big shot staggered  with Quite Baffles in gives a good note and easy on the ears.
  • FatboyMick
    FatboyMick
    Nixon, when i got my Fatty, it had S&S slip ons on it, i loved the look, and the tone, but i hated having to remove the top one everytime i had change to the rear tyre, i went with the big radius, not as gutterall, but has a nice crack to it. But it does come down to personel choice. Just remember, "loud pipes saves lives". Phew, that's pretty profound, i better have a little lay down now, i've spent my wisdom for the day.
  • wildchild
    wildchild
    I have the S&S slip ons and yes its a pian in the neck having to take the top muffler off each time a belt adjustment or tyre change is required.
    Personaly I prefure the S&S sound and torque and will compremise on the time to take the top muffler off for tyre change, this doesn't happen very often so no big deal.
    As for the V&H every man and his dog has got them and I don't think they sound and perform as good as the S&S.
  • HAMM3Rsix
    HAMM3Rsix
    Samson Sidewinders loud and tuned with a tts all good but pipes really are a personal choice my choice was not to follow the pack
    just my 2c
