Online: WideglidingNZ
Hooker vs V&H
  • 1340LOCO
    1340LOCO
    Im looking at putting a set of big radius/ground pounder style pipes on my 07 wideglide and was wondering if anyone knows which of these to brand pipes flow the highest/ make the most power. Im not interested in going to a 2-1 pipe as i dont like the look of them although i know the make more power/torque. Bike is cammed and has atleast a 103 kit from what i was told.
  • Yob
    Yob
    Its a Choice of what you like the best, I have a 2007 s,tail 103 kit crane 310 cams & tts tuner with hooker trouble makers and happy with performace fro idle - 6000rpm.
    Hooker has a deeper exhaust note and no join in the outer covers. cost $475 when new
    vance & hines were $1250.
    I have mates with vance & hines big radius and are just as happy.
    performance wise you would not feel the difference on the road.
    Yob
  • the_mongrel
    the_mongrel
    I really like my VnH Big Radius. When planning the purchase of the bike, the Radius were the only pipes I wanted. I was worried that they might be too loud, but with the baffles in, they are great. Good pull with a heavy breather, and can be loud when you crack the gas.
    You can get them landed here from MnM Cycles for about $600-$700.
    The install is a piece of cake - I did it myself, and then heat shield setup is such that there is no yellowing at all.
    Worth every dollar in my book.
  • m0ngre1
    m0ngre1
    Problem with the hookers is that they are not welded 360 degrees where the header meets at the collector and they leak like a bitch, hence the reason they backfire and pop more than the V & H. Just a cheap copy of the V & H.
    Hooker and V&H where made in the same Factory. Hooker stopped making Motorcycle Pipes late 08. They never produced a set for 06 and up Dyna's
