keeping a black motor black ?
  • monarofan
    monarofan
    cockpit silicone spray, does the job
  •  GLEN
    GLEN
    crc 808
  • CHILLY
    CHILLY
    I use that austalian export tire silicon spray, it works a treat on the blacked out bits. comes in a blue can.
  • BURTO
    BURTO
    Alright, Iv'e now got a black motor and after polishing the rocker covers the other day, I've got excess polish on the top head fins. Tried a couple of things to remove it, but no luck yet!
    Whats the secret?
    Burto.
  • Lastrain
    Lastrain
    Mr Sheen .... dealer recommended it and have found it works great.
  • Stewy
    Stewy
    WD40. then wash with hot water dishwash detergent using a toothbrush. Rinse of with slow running hose
    Comes up like new
