Online: Soapbox2627, Hilly
Ultra backrest fitment
  • UltraBaggy
    UltraBaggy
     Can any help with the fitting instructions for the adjustable back rest on an 09 ultra. I received the kit from M & M but the instructions are to suit the fixed type backrest. I have fitted the main part okay but I am not sure where the correct place for the mounting bracket for the adjustment control is supposed to go. Hope someone can help me with this.
  • rooshooter
    rooshooter
    mine is mounted left hand side onthe frame just under the front of seat
    there are a couple of holes there to fit some small bolts................ bit fiddly but easy enough
    hope ya can work out wat im talkin about
  • UltraBaggy
    UltraBaggy
    Thanks for that rooshooter. I Know were you are referring to. The kit has come short of parts so I am waiting for them to come now with the instructions
    Ultra
