Online: conmore
muffler bafflles ?
  • mintpaul
    mintpaul
    Hey,
    Check out the xl forum for removing baffles. Heaps of step by step info
  • mistajace
    mistajace
    from what ive read you will loose performance  depending on how big of a hole you drill in your baffle. i imaging removing them completely would give you the same outcome. im not 100% sure but it makes sense in theory. another thing i spose youll have to consider is whether or not it will effect your warranty.
    Good luck!
    Jace
  • mistajace
    mistajace
     hmm why the fuck would people who had drilled their own baffle lie about their bikes under performing. seems strange..dont you think.
    and how about your warranty? was that effected? i wouldnt know as i just bought some pipes instead of messing with them.
  • mistajace
    mistajace
     where you from in the gong man im on the sunny coast now but used to live in fairy meadow.
    (sorry bout the thread hijack)
  • mistajace
    mistajace
     agreed.
  • sssmour
    sssmour
    Second that steamer, I am very happy with my SE slip ons. Mind you am planning a set of hooker trouble makers in 2011.
