Flush mount gas cap???
  • the_mongrel
    the_mongrel
    Hi guys
    Is there any difference between the flush mounted gas caps for Aussie bikes? I have one here that does not fit but MnM says it's the right one. The problem is it just will not screw in. Any ideas?
  • wildchild
    wildchild
    No idea but got flush mounts on my 08 Fatboy (Part No: 62823-08A) Although part number has been changed to 62823-08B Since I got mine about a year or so ago.
    Can't see why the gas tank will be any different in Aus.
  • monarofan
    monarofan
    i just fitted some to my 09 fatty, fuel filler side is bloody tight to screw in, way tighter than the original, but it does screw in
  • the_mongrel
    the_mongrel
    Hmm. Tight is right. I can only get it in a half turn. Mine is a 6823-08a.
    It just feels like it will break if I try any harder.
  • wildchild
    wildchild
    I would try it in an 08 and see how it fits.
    Mine screws in just like the standard cap.
  • the_mongrel
    the_mongrel
    A mate has an 08 so I will try again in the morning and if not try his 08.
    It actually looks too long to fit before it would bottom out at the end of the spout.
  • monarofan
    monarofan
    62823-06A suits 04-07 Roadking
    2008 manual quotes part number 62823-08 roadking 08 and later,
    2011 manual quotes part number 62823-08A suits 08 and later roadking and softail (except rocker)
  • monarofan
    monarofan
    just checked the length of mine, old against new and they are the same , and the part number on the box of the ones i fitted, 62818-08, went straight on to 09 fatty
  • monarofan
    monarofan
    well fuck me, why didn't ya do that in the first place, all this pain and heartache could have been avoided, HAHAHA
  • the_mongrel
    the_mongrel
    Yeah I know... I just wasn't sure it would fit and then I would be stuck with a half dremelled fuckup that was only good for the bin!
    Ahh well... all worked out in the end!
