Bassani Pro Street
  • Train
    Train
    Hi Fellas,
    thinking of adding this pipe to the street bob.
    Is anyone running this pipe. Any opinions good or bad?
    Will power be affected being a shorter 2-2 pipe?
  • AJ56
    AJ56
    Walka sells them at VPW he should be able to give you some advise. I have heard that they are pretty good pipes as far as quality goes, I don't know about the sound though
  • Train
    Train
    Thanks mate, sent him a message
    All Bassani Pipes are a Fantasic , They are Ceramic Coated for Perfomance and to stop the Pipes from going Blue. They also use a Longer Baffle that other Brands to cut down the noise and give good back pressure, All the Bassani Pipes are also a Steped Header again for Performace
    The Pro Streets are just a little short and are designed for Big Cub Engines and Drag Race Racing ,
    The New Range that they do are the better pipe Firestorm, Firesweep and Fireflight They are all listed on our VPW Web Site
    I have them all in stock in Chrome or Black I always give the Forum guys a good discount
  • rocket180
    rocket180
    Hi 180rocket here and my first reply,
    Those BASSANI PRO STREET are excellent 2 into 2!!, I have had them on 2008 Dyna Fatbo there are better then the cheap Sonic mufflers that the Sealers give you (just noise).
    They are LOUD and sound very agressive through the gears and they have a stepped tec. 17/8 then 13/4 then 21/4 at the muffler end. I have had my bike dyno with it on and you don't lose any torque nor horse power in the top end. They are just as good as most 2into1 pipes.
    Two types; the turn out type or the shot gun type, I have the turned out type an they take that sharpness out but the shot gun end type is Loud. My personal take is the Pro Street will out perform the Vance and Hinse shorts any time. Just read most American forums. Or talk to my mate Ozrider, he was the one that encourage me to get them. Open for discussion.
    Ride free while you can!!
  • Train
    Train
    Thanks a lot fellas. Appreciate it
