Datamaster Question
  • the_mongrel
    the_mongrel
     Hi lads,
    I just got back from my first short run - basically to see if the laptop was going to work and that data would be collected.  Basically short run around the block a bit.
    the question I have is...   Can I look at this data and know if something was not quite right with the canned map that I am currently using?  I mean it tells me temps and rpms and spark advance data, but I don't know what I am looking at, so I don't know if there is bad knock or anything.
    I am just curious to know if the standard map that the bike is currently running is OK.
    Mongrel
  • the_mongrel
    the_mongrel
    Ando - Mine does not have Knock Retard listed in the graph! Can I add it?
  • the_mongrel
    the_mongrel
    Tiz cool... I just worked it out.
    ZERO knock through the entire ride.
    Is there anything else I can learn from this data. Too rich or too lean etc???
  • the_mongrel
    the_mongrel
    I would just like to know if it was running too rich. I think it is running a little rich - but it would be nice to know by how much!!
  • the_mongrel
    the_mongrel
    Hmm... Ok. How do I do an O2 run? Time to for the manual I think. ;(
