Online: Fletch1953, Ultramick
fatboy forward control
  • abdulraziff
    abdulraziff
    Good day guys,I am looking for a new forward control for my bike....not quite sure wich one 2' or 3',anyone with forward on fatboy,can advice me some product brand.I have look at alot of site the one caught me is 2"performance machine brand,and few other hope to hear soon.
  • shaggz
    shaggz
    Abdul if you can afford the performance machine they are a pretty good product, as far as being able to give you advice on which ones to get though is impossible as it comes down to all sorts of variables to come up with the ones that fit you properly. things like your height, what sort of seat you have on there, what bars you use all add up to a different seating position which in turn determines what length forward controls will suit you best.
    I dont think PM make them for Fatboys,,, There is not many companys that make them for them. Soft Tails ones not fit. Fatboys and Heritage modles have diffrent mounts. The other problem is the Front Fender, I think HHI is the only Brand you can buy
  • wazza-in-oz
    wazza-in-oz
    Is that right Walka? I thought the mounts were the same on all softails? I thought the only difference when buying forwards is that you can't put the 3" forwards on the heritage models because they hit the front guard. Although i am thinking of an evo model Fatboy so not sure on the later stuff.
  • monarofan
    monarofan
    i've got forwards on my 09 fatty, box just said 00 up model softail, they are Supreme Legends brand and i'm running 3 inch plates aswell with no clearance issues
    I didn't think there was a diffrence until I sold a set to a guy with a 07,,,,, All I can say is he was one F#@ken pissed of Customer. Here's the Link to HHI. as you can see they have a sperate Listing.
    http://www.hawghalters.com/#/shop/set/1/22
  • wazza-in-oz
    wazza-in-oz
    I must be blind i can't see the separate listing??? There is 3 options - softail, Dyna and FLH models. Aren't we talking about FLST models?
  • monarofan
    monarofan
    One of my mate just fitted a set of standard 08 rocker forward controls
    to his 00 fatty, they went straight on
  • WozzA
    WozzA
    EVO & 1999 > 2006 TC frames are different...   unsure about the later model 06 onward TC's...
