Key Ignition Light Switch
  • Marz
    Marz
     Has anyone had the hinged weather cap replaced... and how do you do it... bloody thing wont close anymore.
    Looks like the little internal nipple is loose, and there is a clip in the slot from the top... is there an easier way to fix this...
    Don't really want to replace the whole switch if I can avoid it...
    Thanks
  • Marz
    Marz
    Is it still under warrantee?
    No...
    try at your local stealer...im sure something as simple as that would take em 5 mins to sort out and not charge you?
    Surely you gest... around 50 bucks for a completely new switch... didn't ask about the labour.. and I'II stop calling you surely!
    guess I might have to try fixin' it with the old 450gram ball and pein!
    Thanks anyway
  • Burnzi
    Burnzi
    Hey Marz I am in the same basket as u only mine is 23 years old, mine wouldnt close sometimes and on the last ride it came off. lookin for a newy
  • shaggz
    shaggz
    A bit of blue tac under the cap will stop it rattling around. It works on my shovel anyway
