Online: conmore
Primary cover
  • SJ
    SJ
     Maybe post this in the workshop section?
  • old faithful
    old faithful
    Mate I've had mine off a couple of times and haven't replaced them.
    Just give them a visual and if they look alright they should be ok.
    If your worried about them they don't cost much to replace.
    Good Luck!!
  • BAKES
    BAKES
    Infidel it is a simple job to remove and replace the clutch cable, just take your time.
  • BAKES
    BAKES
    Well done, always makes you feel good when its all done. Did you get before and after pics
