Online: GGUser744, speedzter
K&N filters
  • sime69
    sime69
    Me again, wow two posts in a row, I must be a regular!!
    K&N have a few different filters available.  I'm familiar with the HD1499, which has the same shape & metal case as a stock HD element and you can buy for about $100. Wondering if anyone has used the larger RK3909 or 3910 models? They come with a new back plate and the element is nearly the same size as the 'footy' shaped a/c cover on TC models.
    Was thinking about a Pro Hypercharger but after intensive internet research am starting to wonder if they are really just for show!! (no offence to those that have them fitted...  .)
    ...thanks, Sime69
  • sime69
    sime69
    Thanks Scotty
    I'm innerested in the 3910, but if the velocity stack is 'fudged' will the filter still work properly?
    If you have some pix of the filter, pls send to : ssgregor@homemail.com.au and then we can talk furher about the fiddy dollars!
    sime69
  • sime69
    sime69
    Thanks Scotty
    Does the air cleaner element stick out from the stock Harley a/c cover?
    Have you ever re-oiled the washable element?
    thanks
    Sime
  • sime69
    sime69
    OK sweet mate
    When you get the new stack, pls email me (address in above post).
    thanks Scotty
    Sime69
