Online: HD17, John.R, baldy1450
Dyna wiring connector - where is it?
  • sime69
    sime69
    Evening all...
    Apparently all the handlebar wiring on my 2006 Super Glide terminates somewhere under the fuel tank, and I should be able to disconnect the switch & indicator wires at that point, so that I can thread them thru my new Ventura bars and then re-connect.
    I've done handlebar wiring before on a Sportster but on that occasion had nice high risers to allow soldered splices under the bar clamp. It was still a bastard of a job that I swore I'd ne'er do again....but, famous last words and here I am again!!
    Before I consider the hassle of draining & removing the tank, can anyone confirm that's the right place to find the connector, or would it be further back (under the seat. maybe?).
    ta
    Sime69
  • sime69
    sime69
    Thanks for the prompt info, guys.
    Dazza, don't understand your reference to "split" - do you mean the large plastic plug is split? Or the wires for left and right?
    I just realised I'd rather not remove the tank, since it will still have the fuel line to the motor attached. If I undid the front tank mount bolt, can I lift the tank enough to get to the wiring?
    ta
    Sime69
