HYPER CHARGER
HYPER CHARGER
If you buy one, just remove and toss the gimmicky butterflies, and it'll be fine.
Heard the standard Hyper' can be restrictive, maybe the "Pro" is better ?
Yob
I have one on a 103 t,cam with crane 310 cams tts tuner & hooker trouble makers & 2005 springer 88 t,cam the only fault is the foam filter on the end.
it requires frequent oiling to stop fine dust from entering, if you leave it until the K & N is dirty, the throttle blade will have oil & grit that between your fingers is like grinding paste.
since i remove & oil the outer every couple of months it has cured this problem.
after 19,000km the old 96 barrels & pistons were showing no signs of scuffing from dirt.
Yob
