Will a 200 rear tyre work on my 07 Wide Glide ??
  • Rans
    Rans
    Hey guys,
    Has anyone put a 200 rear tyre on a 07 wide glide, or can it be done ?? What needs to be done to do this, or will it go straight on ??
    Any pics or advice would be appreciated.
    Rans
  • 1340LOCO
    1340LOCO
    Well Rans you beat me to the same Question mate. Picked up mine this arvo and im already thinking the 160 just dosent quite cut it. Im interested to see the out come of this. I also picked up a tri-bar tail light on the way home but the pub was calling and therefore the tailight will have to be fitted tomorrow after the ride i have planned.
  • Rans
    Rans
    Glad you got her home brother, has been a great day, went and put a couple hundred ks on the bike today and she ran like a dream. How did it run on the way home, and or your ride today ???
    Rans
  • Daggs
    Daggs
    yes with a wider rim and minor mods
  • Rans
    Rans
    Daggs, someone told me that you might know how to do this... Any tips mate ??
    Rans
  • Daggs
    Daggs
    search back through my posts mate, i have a bit of a write up on what I did
  • BACAMICK
    BACAMICK
    if ur budget is low a 180 se tyre will fit straight in on, put one on my 07 streetbob and it comes up at 187mm wide , there a hd deuce tyre i think , only avalible from a HD dealer
  • Rans
    Rans
    Thanks mate, Might do that first and see how it looks.
    Rans
