Compatible hand grips, pegs, shifter for rocker c?
  • dutchie67
    dutchie67
    Hi All,
    Getting a bit p-off here...love the stealth grips/pegs/shifter...doesn't fot rocker c, sam efor airfoil, X2, and many others....looks like theres not much left! Anyone out there with a Rocker C who has 'fixed' the challenge with something looking right for the bike that DOES fit?
  • Dan
    Dan
    G'day,
    I found there was nothing really to fix... pegs & grips do fit, a lot of the HD cats do say "except fxcw & c" dunno why but I had the willie g grips on the original bars. pretty sure all the softy pegs will interchange...
    goodluck with it
    Dan
  • dutchie67
    dutchie67
    Thx mate...looks like the site.....however when I put in 2010 Rocker it showed me some footpegs I liked so i clicked...guess what it said...'Fits bla bla bla EXCEPT rider position FXCW '08 and later' Grrrrrrrrrrrrrrrr..............
  • Dan
    Dan
    For what its worth, Ive fitted a few pegs... they all said except fxcw Im sure they all mount the same...
