1992 sporty speedo cable
  • ronjm
    ronjm
    I need to change speedo cable on 1992 sporty can you just undo cable or do you have to replace speedo drive as well.
    Cheers Ron
  • kingchops
    kingchops
    You might have better luck posting this in the workshop instead of how to guides.
    hi , the cable just screws out of the speedo drive unit , easy
