Aftermarket wideglide tail lights
  • 1340LOCO
    1340LOCO
    Ive been looking around for after market tail lights for my 07 wideglide and had very little luck. I was after a tri-bar set-up but i am told that there is none available to suit. What have people done to rid there ride of the hideous standard tail light assembely? Any idea or pics would be great.
    I had an 85 wideglide before my 96 softail and loved it. I thought id go back to another w/g for a change and now find myself questioning my decission as it appears there are limited options when buying aftermarket parts and accesories( i dont leave car/bike standard).
    So come on guys show me i may be wrong and what you have done to make yours look better!
  • 1340LOCO
    1340LOCO
    Cheers for that hilly, i was hoping to fill the arch of the gaurd right out,hence why i like the tri-bar set-ups. if all else fails looks like i may do one of these.
  • Rans
    Rans
    Hey mate, I have a tri-bar set up done on my 07 Wide glide, It was done at peter stevens Dandenong, the part number is 69817-07A. It looks awesome, but dont have any pictures at the mo, but There is no way I would have it standard after see'ing this. The guys were also going to fit the Kuryakyn one like above, but I wanted the Tri-bar, and it was well worth the extra hundred or so bucks. If you call peter stevens Dandenong and ask for Zoran, He can tell you all about it.
    Rans
  • 1340LOCO
    1340LOCO
    Cheers Rans and ive sent you an email mate re pics. This kind of info is so handy and will definatly make me go with the tri-bar light.
    This forum has some great members ready to help out with info or tips that make life just that bit easier rather than spending countless hours dealing with twits behind counters that dont know what they are on about.
    I am extreemly greatful for the info.
  • Rans
    Rans
    Hey mate, Check out the TRI-Bar forum in the Dyna section, she is on there mate, I actually out smarted myself and got it to work... Tell me what you think Glenn.
    Rans
  • 1340LOCO
    1340LOCO
    Rans,
    Just checked it out brother and it blew me away. Im getting one asap. Pick the bike up tuesday and if the local stealers have one at a decent price i will be fitting it tuesday night after ive wasted some fuel.
    Thanks for posting the pic
    Cheers Glenn
  • Rans
    Rans
    Glad you like it Mate, It sits flush with the back of the fender too, I think from memory they charged me around $440 fitted. Hope this helps mate. Be sure to post a pic when your done mate.
    Glad I could help mate.
    Rans
