Online: GGUser744, speedzter
T-Max install trouble
  • Brett
    Brett
    Has anybody out there installed a T-Max in a fatbob?Well don't bother cause it won't Fit.After finally removing the fuse blocks ect ect  [wich is no mean feat let me tell ya]  and removing the carrier and ECU, I did the little mod to allow the t-max to slide in to the cradle and I discovered that when installed there is no room to allow the data cable to be left connected when re-installing,situated directly below is another module type thingy,so I can see no way of being able to fit the bastard with the cable connected.Please someone tell me different.Anybody fitted one to an 08 mod dyna??On the flip side is I fitted a set of  V & H BSS and they are a pleasure to work with!cheers
  • cattleprod
    cattleprod
    Mate, the other module thingy is more than likely the alarm. You can either re-locate the alarm or do what i do, slide the alarm module out rear wards, plug your cable in, do what ya gotta do, disconnect cable and slide alarm module back in. I know its a pain in the arse fuck around however, it works. Hope this helps ya some.
  • Brett
    Brett
    Thanks guys ,I have emailed Zippers ,Thanks cattleprod ,I thought I was goin Mad cause I can see no otherway of getting the fucker in there without doing like you suggested.Not much room to work with behind the electrics though!! cheers
  • PKSHED
    PKSHED
    Shit I'm glad I did'nt end up gettin one for mine, went with Gmeikle and the Night rider 02 IED's. Just waitin for delivery.
  • Brett
    Brett
    Be interested to see how the nightrider go's for ya,looks pretty simple
  • cattleprod
    cattleprod
    Brett. It is a hassle thats for sure. It would be good if Zippers made a 90 degree plug that would fit with our alarm modules in place.... sounds like a great after market project for the electricly inclined. Better still if the plug, plugged in on one end as opposed to underneath...
  • Brett
    Brett
    Mate, no dought they will bring out the cable in a couple of months,and charge $30 for it! No reply from zippers as yet, far enough away not to give a fuck I suppose!!
  • Peter
    Peter
    I totally agree,I just wish I was mechanically minded enough to do all repairs myself. Anyway I'll keep trying,at least I don't have to pay for servicing costs and I'm gonna do everything I possibly can myself. Seems like it has always been part of the reason for owning a bike for me anyway. Also seems strange to me that all my other bikes have been carbed bikes and now when I buy my first Harley I'm learning about Fuel Injection and ECM's etc.
  • Peter
    Peter
    Yeah thats true RT/Scotty but with all the blunders that have been made on my bikes over the years by so called experts what have I got to lose??
