Online: John.R, Hilly
BBB Airshock Pump for Fournales Shockies!!!
  • Clem
    Clem
    I know this subject was covered about a year back but I am hoping to get some feedback from those that may have used the BBB Airshock Pump from Cecil Walker Cycles in Melbourne.
    I have an 09 Fatty with Fornales Pan Cruise shocks. To date I have had Magnums in Wollongong adjust my shocks. I thought I'd finally buy a Fournales pump so I can adjust the shocks more often as required. For a Fournales 0 to 30 Bar pump is $280 and a 0 to 60Bar is $450!!!
    Last year a few of you talked about the BBB Air Shock pump which is only $79.95 from Cecil Walkers. My question is has anyone actually purchased and used this pump on late model Softails fitted with Founales Pan Cruise shocks. Does it connect and work well and was 30 Bar sufficient. I know 30 bar would be for ride height which is between 8 & 28 bars but preload minimum is 27 Bar up to a maximum of 55 bar. I was hoping I would not need to go over 30 bar preload for comfort reasons but I do double with luggage occasionally.
    Any info would be appreciated.
  • Clem
    Clem
    Thanks Hilly, I just bought a 30 Bar pump on ebay for $53, free shipping!!
  • Clem
    Clem
    Thanks Dodgeydave
    Ive got the same pump on the way via Ebay. Glad to hear it works as it was a bit of a fingers crossed kinda purchase!!
