Online: Stuart
Stage One Kit.
  • JC&S34
    JC&S34
    18 years ago
     Just had a stage one kit fitted to my 07 Dyna Glide.Now it runs heaps cooler and revs out heaps quicker. Open pipes sound great, though REALLY loud. There is some exhaust popping when I back off quick after a big handful but otherwise it runs great and goes like a rocket.
  • cattleprod
    cattleprod
    18 years ago
    what pipes/mufflers and AC did you put on?
  • kingchops
    kingchops
    18 years ago
    Would be great to know some details of what was done and who did it, ie what pipes, AC and any fuel tuner that was used?
    Also how do you know you oil temp, do you have a gauge fitted?
  • JC&S34
    JC&S34
    18 years ago
    Screamin Eagle Race Tuner, Screamin Eagle Pro aircleaner and S&S slashcut slip on mufflers. I had it fitted by Frasers. Temp is measured by how hot my knees get when I'm sitting at the lights. Hardly scientific I know, but it definitely feels cooler. Prior to fitting the kit it was running so lean it felt like it was running out of fuel at times. Now there is a trace of soot in the pipes and they are black, so that it's not running as lean and therefore must be running cooler
  • kensim
    kensim
    18 years ago
    jc&s34 my bike is fitted with the same gear,the popping is alittle bit to much fuel when u back off,frasers just use the closet map on the tuner for ur pipes and filter,a good dyno tuner will get rid of this.
  • JC&S34
    JC&S34
    18 years ago
    The bloke in spare parts has assured me they will make it run perfectly, it's just a matter of fine tuning. I took some convincing on his behalf to get me to buy it, but it's a pretty impressive package. If were to fit an oil temp gauge about what temp do they run at?
  • AUSSIE2
    AUSSIE2
    18 years ago
    Speaking of tuning, does anybody know a good dyno service on the Gold Coast ??
    18 years ago
    what about good dyno in Perth....
    18 years ago
    Thanks Stix... Supercycles are down the end of the road. Will try them but they tend to be expensive.
  • JC&S34
    JC&S34
    18 years ago
    I think where ever you go in Perth it's about $100 bucks an hour. I know Supercycles charge $ 175 an hour if you supply the parts.
  • BACAMICK
    BACAMICK
    18 years ago
    2007 883XL, Black, SE Street Performance Mufflers, SE AC, Vance & Hines Fulepak, Forward Controls, Harley Skull derby, points cover & fuel cap, Kuryakyn ISO grips
    ok ive been drinking
