I thought I would start a thread on this topic as I couldn't find much about helmets on this forum.
I started with a Rjays open face 3/4 but found that with it's "mushroom" like profile, at speed the wind would be trying to rip my head off. I now have a vintage 1971 Auther Fulmer open face which is great, apart from the wind noise. My main concerns are that it's not A/S approved and more importantly how well it would perform in a crash.
Would love to hear your thoughts on which brands/styles etc you prefer.
KBC open face which at 10 year old is probably past it's use by date but has been a very good comfortable helmet.
New NEX open face which is comfortable & light enough with a lot less noise than the older KBC.
2 x Arai Profile (Sinister) full face helmets. Arai are the only full face that suit me & don't give me a headache. Not cheap but you get what you pay for.
Spent over 25 years with open faces of all varieties and usually the cheapest versions ( $50 helmet for a $50 head????).
Considering some comfort these days an looking at the Nolan N41, it has the screen. Heard nothing but good about these for comfort and user friendly as the old fogged glasses and saturated rag around the face in torrential rain may be the way of the past for those long trips.
Tried some on and the vision seems OK
Hi Guys
Being on the wrong side of 55yrs old I wanted some comfort and have just bought a HD Jet 11 helmet with a flip up visor.
We did 1000klms on long weekend (500 each way) and I found it to be excellent,no rattling, no visor blowing up at speed and it does not try to pull your head off at Freeway speeds. At the end of each days ride my eyes are not roadmaps and rain is not a problem for the eyes.
Should have done it years ago.
Phil.
Yep, all mine are the same size M (57-58)
I just got a HD Jet, it has a screen and its the first time ive used one but am finding it really good.I also have an RJ's Sturgis but the wind noise drives me crazy, I even started using ear plugs with it
I just ordered one of these....
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=250659277418&ssPageName=STRK:MEWNX:IT
Have had special Nolan for nearly a year(after 20years on the Open)does both OF or FF Flat black, light weight, don't really care about noise and other shit seems OK in these areas.
Does have proper clip instead of those stupid rings so easy to do up, and my teeth will be happy now that wayward rocks can no longer threaten them..
And don't ask me where I bought it,,cause I won't tell ,, I don't want you buggers buying one, if you do,, then I won't be the only one to have one and all my Cred will be lost forever!!!!!!!
I reckon my AGV crumple zone full face might do a slighty different job than the german helmet I just bought
I know... it was the only flat black one in a major Melbourne store.
Suits the gay rice burner it was paired with anyway.
Ha!
This still goes under "What helmet do you wear" right ?
I live in the city. There is a good chance if I have a accident, it wont be at 100k's
Just bought an X Rated 'Peanut' helmet. Hopefully won't be too loud with the short shots. Haven't tested it yet.
