SPECTRO 6 SPEED where?
  • cm364352
    cm364352
    Does anyone in the Newcastle area know where I can get spectro platinum 6 speed from?I can't find it here in Taree,so I'll take a run down to Newie when this fugg'n weather clears up and try my luck there.Cheer's WAZ!!
  • The Don
    The Don
    Try this site, http://stores.ebay.com.au/OBTAIN-ACCESSORIES , he carries a variety of Spectro stuff, delivery is quick.
    Cheers,
    Cris
  • monarofan
    monarofan
    that oil is some good shit , had it put in my bike this week , what a difference it makes
  • cm364352
    cm364352
    Thank's Cris,I'll give that a go.Yep monarofan have read some good report's on it,so going to give it a derby and see what happens.Cheer's WAZ!!
  • cm364352
    cm364352
    Good work agian Cris,I tried the link on that page and could'nt find any order/contact details so have sent a PM off.The e-bay site you pointed out has spectro heavy duty 75/140,but not the 6 speed i'm after.He has some other good stuff tho(fork oil,brake fluid ect) worth a look. Cheer's again WAZ!!
  • The Don
    The Don
    No worries Waz, the bloke in Qld (eBay site) is the Aust distributor I think.
    Cheers,
    Cris
