07 Wide Glide Master Cylinder..Recall???
  • Rans
    Rans
    Hey Guys, My Master Cylinder Looks as though it is leaking, and has been for sometime by the  look of it, A mate said he thought their was a recall to fix these, Does anyone know anything about this ??? surely it should not be stuffed after only 7000Ks.....?????
    Rans
  • cm364352
    cm364352
    I've read something about the lids being done up too tight causing them to leak,nothing about a recall though!!
  • FXD09
    FXD09
    Pretty common on quite a few models i hear. The local dealer here knows the part no. off by heart getting mine done for the 2nd time
  • Crebbo
    Crebbo
    Had mine replaced on my 08 Heritage, always looked wet around cap seal then paint started to blister ,was away on a run went to a Harley dealer and they replaced the unit with no argument. Bike was under warranty but they seemed to know about this issue they also pointed out a problem with the compliance sticker on the frame peeling and being VOID, this dealer was in Tammworth and supplied great service ,even though I had bought the bike in Canberra.
  • Crebbo
    Crebbo
  • Crebbo
    Crebbo
  • Rans
    Rans
    Will this be replaced on my bike for free, or will they charge me ???? when I bought it, I also took out the extended 3 year warranty... The master cylinder is all blistered and looks about 10 years old, not suitable for a bike that has only done 7 thousand KS, there is obviously an issue there somewhere.
    Thanks
    Rans
