Online: B0nes
White wall tyres
  • malibu_lxi
    malibu_lxi
    What do you clean them with . to keep them nice and white.
    And is there any other brands that sell a wide white wall tyre's the same as the original one's
    Thanks
  • tarmac
    tarmac
    Wet the tyre then scrub lightly with powdered ajax using a soft bristled brush and then hose off and wipe down.
  • Kustomtown
    Kustomtown
    Jif and the scourer Phantom mentioned
  • Kustomtown
    Kustomtown
    Mate, it worked a treat on my old Deluxe. I never actually tried the actual wheel cleaner.
    I'd be interested to know how they compare...
  • Poolie
    Poolie
    Stainless steel soap impregnated pot scrubbers.  Work like magic!
  • that guy
    that guy
    Thanks Phantom for the scientific trial, excellent work.
    I shall give the Harpic bog cleaner a go next time to get the 'shit' off the white walls.
  • bigen
    bigen
    any one used that white wall paint,I believe you can paint it on any tyre to make them white walls
  • Deadwood
    Deadwood
    Handy thread now that I have white walls. Bloke who put them on said to use Gumption, anyone used that before?
  • Deadwood
    Deadwood
    Bueller?
