Removing Thundermax installing Mastertune
  • hellboundpig
    hellboundpig
     Removing Thundermax Tomorrow and installing TTS Mastertune i am sure i will be asking you guys some questions Wish me luck.
    07 SOFTTAIL STD 103 211 CAMS VANCE & HINES BIGSHOTS SCREAMING EAGLE HEAVY BREATHER 0.30 COMETIC GASKETS PORTED HEADS.
  • hellboundpig
    hellboundpig
     Removed Thundermax today and installed factory ecu and TTS loaded a map very close to my build when,t for a ride out to my test area bike runs great cant be more happier
    if it runs any better than that with a v tune i would be estatic did all the work my self no popping no pigging.
  • the_mongrel
    the_mongrel
    NICE!!
    Mine is like yours mate. It runs brilliantly with a canned map - so I have no real reason to play with the tune, but will do data runs to see what is going on, none the less.
  • hellboundpig
    hellboundpig
     I Think i will do the same Mongrel just to be sure everything is sweet at the moment couldnt be Happier goes like a raped gibbon.
  • the_mongrel
    the_mongrel
    Bwahahaha Nice!
    Yeah mate, I know what you mean. I was not expecting to just drop a map in and go screaming up the road. I was expecting some jitters that I would need to iron out, but nope. Goes like a bought one. I seem to have good fuel economy too. I hit 300 clicks and still no fuel light - so can't ask for more I guess. :)
  •  GLEN
    GLEN
    Ozroder - yeh I watched the dyno tune being done on mine through the window of the booth the other day and it was quite interesting to watch the motor smooth out in vibrations as he went through the VTune process they must feel really smooth in the B motors
