Online: Wanderer57
LED taillight problems
  • safadao
    safadao
    Been reading about them in the states. the tri-bar ones are having heaps of issues.
  • Paul.C
    Paul.C
    Can you get some aftermarket LED's for it ?
    These things are cheap as chips , It's only expensive when it comes in a HD box.
  • safadao
    safadao
    I'm sure if you are handy with a soldering iron you could fix them. I doubt you could blow all LEDs in the circuit, sounds more like a dry joint.
  • Paul.C
    Paul.C
    Good to hear they replaced them for you.
    And yeah if they have changed the design then they must have had problems.
