Online: reeltor70
What make is this exhaust system?
  • keego33
    keego33
    Can anyone tell the make of this exhaust system, thanks.
    Gulfstream is offline Add to Gulfstream's Reputation [script removed] Report Post
  • keego33
    keego33
    Are they available in Australia.
  • keego33
    keego33
    Hey Bones, many thanks.
  • vijay5250
    vijay5250
    We had a nice clean break where the Y-pipe connected to an intermediate pipe. This is because someone else had attempted a repair with nothing but muffler tape. Um, hello? They only use that stuff in places like Nicaragua, okay? Buy a damn adapter pipe and fix it right the first time!
    After a close scrutiny, we decided the Y-pipe was more or less intact, if somewhat dinged up. At this point function far outweighed form so we resolved to make the Y-pipe work. We spent a couple hours trying to clean up the mangled break but found the old muffler clamp had fused with the end of the old pipes. There was no banging it off.
    No problem; the Y-pipe had plenty of length left for an amputation. Because we still don't have a Dremel, we used Mr. Hacksaw and got a good workout cutting through the end of the pipe.
    Exhaust Systems
  • 883n Harley Convert
    883n Harley Convert
    Not too sure about the pipe, supposedly their great for performance, however I reckon their pretty hard on the eyes!!
    Bassani Road Rage is the same
  • Midnite
    Midnite
    Or you could go with a d&d bobcat, which i have on mine.
  • skirtster
    skirtster
    Midnite did the bobcat improve performance,is it loud,are you happy with quality,looks tuff I like it.
